Specify the full CMS version you are using, including the revision number.
1.8.13
Installation Method
Docker or Custom install
Docker
Operating System
The operating system the CMS is installed on
SUSE 15.1
It would appear my upgrade was successful but I want to reclaim some disk space from the upgrade process. Can I delete the import.sql.done file?
Thanks!
