Displays -> displays "faulty" 2 errors
in the displays → displays section, the “faulty” column tells me that there are 2 problems on some of my displays, but I can’t understand the error and therefore can’t fix it.
Here is a screenshot.
xibo en defaut 2 erreurs
Have a nice day,
Collect the screenshot where you will have the latest status update. Or you could check your logs and filter for the display.
