Hi, I’m trying to display an SSRS report that another department created. The Webpage widget reports “please enter a link” when I put the URL in. I expect it’s looking for an .html or .aspx extension in the URL, which isn’t there. Is there a way to make it accept the URL or modify the URL to work?
Sample (sanitized) URL:
http://SSRS.domain.com:8180/ABreports/report/Data%20Dashboards/Site Briefing Report&rs:Command=Render&rs:Format=HTML4.0&rc:Toolbar=false
I upgraded to 3.3.3 and it’s working with %20 in the URL.
It validates that it is a properly formatted URL (which doesn’t allow spaces), so I think that makes sense! Glad you have a solution.
