I’d like the ability to use an advanced SQL filter on the DataSet View widget to be able to leverage tags applied to that display.
User Story
A user has a single layout that they’d like to distribute to multiple clients. This layout uses a dataset view to display a menu category. In the incoming dataset we have a field that identifies the store that record applies to. We then tag the displays located in that store with the appropriate tag, and use that tag in the advanced SQL filter for the dataset view widget.
