Hi in display menu i’m not able to change the display settings.
see screenshot
Frank - is this on a CMS we can access? If so we might be able to track down the problem faster. If so you can you send us the details privately?
Thanks,
Dan
Hi Frank,
It’s a bug on fresh 1.8.0-rc2 - https://github.com/xibosignage/xibo/issues/994
The work around would be to edit the android display profile change download and update start/end time to something else than default 00:00, then edit it again and change it back to 00:00.
I’ve fixed that on your CMS Instance, so you should be able to edit your display now.
