On a TV UHD, the display is not done but on all the TV while on my other screens (TV different) the display is good.
Would you be what’s wrong or how to solve the problem?
Thank you
Thank you
Doublecheck resolution in display properties if you are using android.
I don’t use androit, it’s W10
Oh windows 10.
Then change the windows resolution.
