we have a Amazon Fire TV Stick with the XIBO App installed and we looked up this tutorial: Installation Guide on how to set it up with our CMS but we do not have the “Add Display(Code)” Button on the top right of the Displays Page. When we manually try to connect the XIBO App with the CMS it always fails on the CMS address.
I tried using http / https. I also used all paths I am aware of but nothing works. The CMS is installed in /html/xibo-cms-2.0.3 . What can I do?
Thank you for your help, that actually worked. Now I had to authorise it which also worked and I assigned a Layout to it but when I click manage it is not downloading even though I started Schedule Now and checked the “always” checkbox.
There’s too many variables then as to why the Player might not be able to download for me to give a quick answer. I’d suggest looking at the Player logs to see if anything is being logged in that regard and start your search from there.
I checked the status inside the app. It’s un-licensed.
It tells me to check the e-mail pool but I am not sure where to go to license it. We had a old Display which was licensed but we had to remove it. Can I use it’s license and if yes - how?
