Disable timeline module
Would be nice to be able to disable timeline element without having to delete.
I agree. Sometimes you need to temporarily disable a timeline element. A kind of checkbox or similar would be really helpful so that you can easily switch between showing the element or just ignoring it. It would keep its duration and timeline position but the player would simply skip it until it is activated again.
Is this something which is available for a new version ? Sometimes you have added a nice item, and it would be nice you can just say, show 0 seconds, or temporarily disable it, without deleting the item.
It’s a feature request but it hasn’t been implemented yet. If and when it is implemented, we comment on the Feature post to let people know that.
