Hello.
I am a beginner in the collection function of statistical reports.
It may be a very basic question, but please tell me if you know.
After reading the documentation, I learned that there are 3 types of aggregation levels: “individual”, “hourly”, and “daily”.
What does “individual” refer to?
What is the difference between “individual” and “hourly・daily”?
I’m sorry to ask you a basic question.
I would appreciate your reply.
Individual will record the start and finish time of each item individually and send that back to the CMS with each collection interval.
Hourly will record each item once, the total number of times played and the length of time played during the hour, and send that back to the CMS on the next collection period ‘after’ the hour period is up.
Daily will record each item once, the total number of times played and the length of time played during the day, and send that back to the CMS on the next collection period ‘after’ the day is over.
With Individual you will get back a vast number of records (one for each play of the items you are collecting stats on) where as with Hourly / Daily aggregation you would get the total number of plays and total playing time (one for each item you are collecting stats on per set aggregation period).
Player playback started at 08: 06.
・[Collection interval: 1 minute]
・[aggregation levels: individual]
At 08: 40, you changed the aggregation level from [Individual] to [Hourly].
・[Aggregation Level: Hourly]
The log did not appear to be aggregated.
I want you to tell me if there is something wrong with the setting.
When I checked now, the status of the display was out of date.
The layout has not changed, so I think it is due to the above configuration change.
I will attach my log.
I would appreciate it if you could check it if you have time.
[Note]
・Around 13: 17, the collection interval was changed to [1.5 hours].
・I killed the player once at 13: 42 and 13: 56.
