The below compatibility guide may be used to help decide on a device to run Xibo for Android. Please refer to the Recommended Android Hardware topic for our choices.
| Device Name | Firmware | Conclusion | Comments |
| MiniPC MK809 III | All | Avoid | Reports of Xibo for Android closing after 15 - 30 minutes playback. Suspected issue with Memory Management in the firmware. |
| Minix Neo X5 / X5 Mini | 4.4 Latest | Recommended | The X5 does not auto power on. X5mini does |
| Minix Neo X7 / X7 Mini | 4.4 Latest | Recommended | The X7 does not auto power on without adjusting a jumper on the motherboard (which entails opening the case) |
| Minix Neo X8 | All | Suitable | Will likely become a recommended device after extended testing. |
| CX-919 / RK3188 | All | Avoid | Reports of Xibo for Android closing after 15 - 30 minutes playback. Suspected issue with Memory Management in the firmware. |
| Rikomagic RKM MK802IV | All | Avoid | Failed occasionally during testing, particularly with intensive content such as images / video. Also got a little hot. |
| Rikomagic MK802IIIS | All | Avoid | Failed occasionally during testing, particularly with intensive content such as images / video. Also got a little hot. |
| MyGica ATV582 Quad Core Enjoy | Latest | Suitable | Reports of some firmware causing the device to reboot if the connected display turned off. Once rebooted videos display at an incorrect resolution. Fixed in the latest firmware. |
| RKM MK902ii | Standard | Suitable | Reports of excellent performance and reliability. |
We welcome any feedback for the devices listed on this guide.
Please note: We encourage our customers to perform their own testing before reaching a decision on the device they want to use. Not all devices are tested by Xibo Signage.
