Hello everyone, we have created libraries and every day is updated with new files. We need to completely delete the library with all its files.
Example: I have a library called absences_lib and daily load that library file.
Now to remove this library must eliminate one by one all the files loaded in the last 3 years, Multiply this for a hundred libraries … how can I speed up.
