Delay startup of a playlist in a zone
Hi!
Is it possible to delay the startup of one playlist inside one zone so that I time it correctly with the slide that it’s supposed to show the embedded code from another playlist inside another zone?
Basically I would have a paylist with pictures in the first full screen zone and in the second zone I would like to have a text that shows up ONLY on one specific slide on the first playlist.
So on slide let’s say 3/5 there is a picture and I would like to show the embedded code inside the second zone only for that slide (3/5).
On older versions (Xibo 3.x) this was possible and it was pretty straightforward to time the playlists and regions, but on Xibo 4.x I am a bit lost.
Thank you in advance for your help!
You can do this using a spacer widget inside the playlist containing the text.
Please note though that it has never been possible to guarantee the timing of those things, one started each playlist/region runs independently.
Hi Dan,
Thank you very much for your reply! This was exactly what I was looking for. So far it works as expected and it is surprisingly pretty reliable. No clue how I could miss the spacer widget…
For anyone else who is maybe looking for another way, you can also do it by embedding a custom JS with setTimeout function. This is less user friendly (and a pretty “dirty” solution) but it also does the trick.
