It could be a good idea to have an option to set a default setting for transitions.
For example fade in/out for images, 1000 ms - so you would not have to do this for every image.
if you want to add a default transition for images per example here is what i did :
Go to the modules folder and look for image.module.php
open the file and look for public function SetRegionInformation($layoutid, $regionid)
you will find :
// Any Options
$this->SetOption(‘uri’, $this->storedAs);
add the folowing :
$this->SetOption(‘transIn’, “fly”);
$this->SetOption(‘transInDuration’, “1500”);
$this->SetOption(‘transInDirection’, “N”);
to make the default transition fly north for 1.5 sec
for text in the timeline how can I do the same ?
thanks
Look for the file : text.module.php, go to the function AddMedia() and
before the end add the following to make the inTransition random otherwise
you set it manually:
$trs = rand (0,1);
switch ($trs) {
case 0:
$this->SetOption('transIn', "fly");
break;
case 1:
$this->SetOption('transIn', "fadeIn");
break;
$this->SetOption('transInDuration', "1500");
$trs = rand (0,7);
switch ($trs) {
case 0:
$this->SetOption('transInDirection', "N");
break;
case 1:
$this->SetOption('transInDirection', "NE");
break;
case 2:
$this->SetOption('transInDirection', "E");
break;
case 3:
$this->SetOption('transInDirection', "SE");
break;
case 4:
$this->SetOption('transInDirection', "S");
break;
case 5:
$this->SetOption('transInDirection', "SW");
break;
case 6:
$this->SetOption('transInDirection', "W");
break;
case 7:
$this->SetOption('transInDirection', "NW");
break;
Best regards.
KAMOUNI Mohamed
Contact : ( +212 ) 6 60 93 99 81
Software & Network Engineer
GNU/Linux user # 497173
Ubuntu User # 29208
Thank you very much !
Hi Peter,
i have been looking in the default transitions, but this is not implemented (yet)?
When I am on a cloud hosting I cannot change these settings myself, am I correct?
Regards, Peter
It’s not implemented and not in the roadmap as far as I know.
Also you’re correct, as that would require direct code changes, that’s not possible in our Cloud - keep in mind also that the code snippets here are from 1.7 series.
Any wayt to set up transitions at layout level. So that all content under a layout will use these trasition settings?
A ‘Default Transition Duration’ was implemented for V2 which is available from the ‘Settings’ page under the ‘Defaults tab’:
Work is currently being completed to bring a ‘Default Transition Type’ for In/Out and is planned for the 2.2.0-alpha2 release.
This topic was automatically closed after 22 days. New replies are no longer allowed.
