Dataset widget no displaying data
Hello Dev Team,
After upgrading to Xibo CMS version 4.1.2, some users have reported issues with their dataset widgets not displaying data as expected. Specifically, they are using a dataset widget that I cannot locate among the current dataset widget options in the CMS (see attached image).
The issue seems to be related to the widget’s appearance settings. In the provided example, the widget is supposed to display meeting times and dates under the “data message.” I have tested the static templates to rule out dataset issues, and those displayed correctly.
Could you please advise if this widget style is still supported in the current version or if additional configuration steps are required to restore its functionality?
Thank you for your assistance!
