Windows
unknown
I am very new to javascript so that really doesnt help, I’m sorry about that, but from all the reading that I have done it seems it should be reasonably easy to achieve what I am after, my issue is trying to find the right workaround:
It seems like I need a hybrid dataset view/ticker widget, I need to add some custom html if I add it in the dataset ticker “Main” template, that same html gets repeated on every line but I only want it once. I cannot add custom html to the dataset view.
here is a link to an example of what I am trying to achieve:
https://www.tablefilter.com/alphabetical-pager.html
The table would be filled from the dataset and the alphabetical buttons would filter table rows.
I already have a dataset ticker running with filters, it just cycles through all the matching data, it would be really nice if the end user could select the letter rather than having to wait for their name to scroll past.
I have also successfully created some javascript buttons modifying links to external images - so the interactivity side of it isn’t really the question (I know it works), but more about combining the button functionality with the dataset widget output.
Am I trying to something that just wont work or is there a different path I need to consider?
