I’m using the dataset ticker to display 4 simplegauge items at a time. I get the first four, then when the page transitions to the next screen, it’s blank (sometimes the correct header shows up). Is there some HTML I should add to refresh the javascript?
Settings:
Configuration page:
Lower row : 0
Upper row: 0
Number of Items : 0
Appearance page:
Background #ffffff
Effect: Paged, no transition
speed: 2
Items per page: blank
I can’t attach a zip with the code.
dataset is:
Node, Response time, Interface, percent in, percent out, index, percent loss (3 rows).
