Hi I’m using latest Xibo docker version
and my regional date is Jalali in administration settings
i setup a dataset in dataset menu, with three column included start and stop (date type) and content text.
in layouts menu after i added dataset ticker widget , inside filter tab i want to use query , but the problem is the now() query conflict with my default calendar type setting because start and stop date doesnt effect on my dataset and it show continuously
so how can i write query with my jalali calendar ?
