Dataset Elements
Win @win11
Can anybody explain how to get the dataset elements going?
Do I have to add a String element for each slot I want to display? I’m asking because with static templates it does automatically put a new line for each entry. But with the seperate elements it does just one slot. Any way to edit the static templates or make one yourself instead that has the proper static template behaviour but with better text-alignment??
