Data set Chart - Filter to show only info for Dates beyond current date
Xibo in the Cloud
Microsoft
Hi, I have a golf club fixture list uploaded as a csv, I can pull the data out of this file and display it within a DATASET CHART, however I want to filter it to show only the next 10 events from the current date , i.e. as an event happens the chart drops that event and bring in the next (10th) event.
Colum 1 is the Date on the csv in the format dd/mm/yy and is defined as a date field within the column
I think I need to use the advance sql clause but it has been some time since i have played with SQL any help appreciated
I would like to achieve the same thing DATE(Start) = DATE(NOW()) did not work for me
Hi There
I fixed it as follows
SQLDATE>= NOW()
Where SQLDATE is a column that is formatted in the normal SQL format( YYYY-MM-DD HH:MM)
I then limit the rows to show 10 events, works a dream
