Custom widget not showing in layout editor
Hi I am relatively new to Xibo and am trying to create a custom widget in Xibo v4.
It is a relatively simple widget where a user in the layout editor can select from a select list of radio stations, where the selected one will be streamed on the displays the layout is published to.
I have created a module for this which shows in Administration >> Modules, but when I enable it and go to the layout designer, it does not show up in the widget list.
This is my module’s xml file saved in the custom/modules directory:
<module>
    <id>xibosignage-radio-streamer</id>
    <name>Radio Streamer</name>
    <author>Max de Groot</author>
    <description>Stream a selected radio station</description>
    <type>radio-streamer</type>
    <dataType>message</dataType> <!-- Unused but required -->
    <assignable>1</assignable>
    <regionSpecific>0</regionSpecific> <!-- Not tied to a visual region -->
    <renderAs>html</renderAs>
    <defaultDuration>60</defaultDuration>
    <properties>
        <property id="station" type="select">
            <title>Select Radio Station</title>
            <options>
                <option name="https://www.mp3streams.nl/zender/skyradio/stream/8-mp3-128">Sky Radio</option>
            </options>
        </property>
    </properties>
    <stencil>
        <twig><![CDATA[
            <audio autoplay loop style="display:none;">
                <source src="{{ station }}" type="audio/mpeg">
                Your browser does not support the audio element.
            </audio>
        ]]></twig>
    </stencil>
    <onRender><![CDATA[
        // Ensure layout scaling continues to work
        $(target).xiboLayoutScaler(properties);
    ]]></onRender>
</module>
Can anybody help me figure out what I’m missing? I think I might be a bit confused about the differences between modules, widgets, and templates.
