Docker is throwing an error… I have no idea how to get past this. Any help is appreciated. Note that I don’t think it matters, but I don’t currently have a DNS on this server… it’s behind a DMZ. Docker appears to be working correctly though.
bfadmin@signage:/opt/xibo/xibo-docker$ docker-compose up -d
ERROR: Couldn't connect to Docker daemon at http+docker://localunixsocket - is it running?
If it's at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
bfadmin@signage:/opt/xibo/xibo-docker$ docker-compose --version
docker-compose version 1.13.0, build 1719ceb
bfadmin@signage:/opt/xibo/xibo-docker$ sudo docker run hello-world
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
1. The Docker client contacted the Docker daemon.
2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
3. The Docker daemon created a new container from that image which runs the
executable that produces the output you are currently reading.
4. The Docker daemon streamed that output to the Docker client, which sent it
to your terminal.
