Is there a way in the Xibo CMS to create an interactive button that launches a 3rd party app? The app would take over the screen and then when they are done, would close back to the Xibo Playlist / layout.
We want to integrate a selfie pic app into the touchscreen.
I am using webhooks which triggers the layout that is stored on the player via interactive layout. When the layout is triggered, it shows a flashing layout with a warning message in it. You could do something like trigger the app via the command module.
