I have version 1.7.5 of CMS installed on a Windows 2012 server (Windows players) and was initially serving only “french” players with Forecats IO and the default language for the CMS was set to french. Everything was working fine… until I added a player that needed to display the english version Forecast IO.
The Forecast IO module is configured in two different layout (FR and EN) and the language is set respectively in the “appearance” tab. This doesn’t seem to influence the display of the information. On the other hand, the information retrieved from “Forecast IO” is in the correct language.
The information seems to be following the CMS default language. I have looked for similar information and could not resolve it with what I have found so far.
I did check all the international settings before posting… but might have missed something.
Hope someone can help.
Francois
