We currently have the CMS running on a Win 2008r2 VM.
Since Docker is recommended for CMS 1.8+ does anyone have recommended hardware for the CMS.
I’ve never used Docker and I can’t find any recommendations on the Docker CE site.
Anyone know, if Docker will run on just about any new hardware?
Or does Docker require special BIOS virtualization settings/capabilities?
We discovered when trying to install Docker on a virtual machine it can’t be done because you can’t have 2 hypervisors. Since I’ll be building a dedicated machine for the CMS I want to make sure it’s the most ideal setup.
