Hello
i am running Xibo CMS 2.3.7 Inside a hypervisor VM based on Ubuntu 18.04 standard.
I am having problems with the e-mail settings and functionality.
Upon installing the docker I have configured the config.env file with at this point every possible combination of settings and yet i can not use TFA nor Stats / error mails.
The mail server that I use is in a hosting company and i had them give me all possible combinations of server-name/domain name and i still cant make it work.
The hosting company provides me with two options to use mail:
server##.hostingCompany.com
or
mail.DomainName.com
They do not use SSL/TLS for the outgoing (i was advised not to use it anyway)
And i have tried most of the possible port numbers.
The settings bellow are the ones that i use on my phone and other mail clients yet Xibo does not seem to like them. I really dont want to use google.
My current config is as follows:
SMTP Server Hostname
CMS_SMTP_SERVER=server##.HostingCompany.com:25
SMTP Username
CMS_SMTP_USERNAME=Username@MyDomain.com
SMTP Password
CMS_SMTP_PASSWORD=Password
Use a TLS Connection YES/NO
CMS_SMTP_USE_TLS=NO
Use a STARTTLS Connection YES/NO
CMS_SMTP_USE_STARTTLS=NO
Rewrite domain (the domain your email will appear to come from)
CMS_SMTP_REWRITE_DOMAIN=MyDomain.com
Hostname that we should identify ourself to the remote server as
CMS_SMTP_HOSTNAME=server##.HostingCompany.com:
Can the From line be overridden in the outbound email
NB GMail will rewrite the From address anyway so it’s not important
for GMail - YES/NO
CMS_SMTP_FROM_LINE_OVERRIDE=YES
The second trouble is that I have enabled a Password recovery by mail.
Whenever I try and test password recovery it just says “User not found”. I assume this is due to the mail trouble.
Any help/Advice is much appreciated!
