Installation Method
Docker
Operating System
RHEL 7.9 (x86_64)
I followed the Docker installation. All the containers start up just fine, but when I go to the CMS homepage, all I see is “It works!”. I ran interactive shell into cos-web, did some troubleshooting and determined (by running http -S, etc) that none of the .conf files in /etc/apache2/conf.d/ seemed to take effect even though httpd.conf has “IncludeOptional /etc/apache2/conf.d/*.conf” in it.
As a blind attempt, I tried cat’ing all of the /etc/apache2/conf.d/*.conf and appending to /etc/apache2/httpd.conf, and the CMS homepage started showing up just fine. Has anybody seen this, and what would be causing this?
I tried other versions (2.3.3 and 3.1.2) and I’m running into the same issue.
Thanks,
