I have got a project where I need to install Xibo client on 4 screens, one screen in each floor. I am wondering if there is a way to feed 4 smart screens from only one PC??
Probably yes, if your PC can support that and if you will be able to connect all screens to it.
Then it will effectively have 4 screens, so you will need 4 Xibo for Windows players.
http://xibo.org.uk/manual/en/install_windows_client_multiple.html
Then open Xibo options and adjust the DISPLAYID (hardware Id) - all screens will be separate in the CMS and will be able to display different content.
Then you will need to create display profiles with correct offsets and assign them to correct displays.
If the tvs got a network port. Can the content be displayed on each screen via an IP address?
