Installation Method
Docker
Operating System
Ubuntu 22.04 LTS
So I have an issue which is getting more annoying by the day. The more players connected, the longer downtime we have. At this point I am pointing between local Apache services installed for SSL or Docker CMS-web image.
Our employees are getting alot of time-outs lately by login in to the CMS portal and making changes to layout/display/campaign etc. Sometimes it responds after 1 min, sometimes after 15 min. Sometimes in between those minutes. We also see this on our display when requesting new content.
Already tried to up the max connection limits on Apache and in config.env but it seem the higher the number, sooner the time-outs come or takes longer to resolve.
Currently tried to run this on a different server, moved data from Ubuntu 20.04 to a fresh 22.04 LTS with almost everything default as settings.
How do you guys handle 200+ displays on 1 xibo CMS.
Do I need to make changes since 200+ displays are asking more connections per sec/min ?
