I have been using Xibo CMS 1.7.9 + player for Windows for a few years.
Is it possible to use player for Linux on CMS 1.7.8 ? (I tried but seemed cannot)
If the CMS system need to be upgraded, do I need to rebuild the layout from ground up ?
Please help. Thanks a lot.
The Linux Player works with v1.8.12 and later of the Xibo CMS.
You should be able to upgrade without having to start again, use the upgrade instructions appropriate for your installation from here: Upgrading the CMS
