Every about 10 minutes the Android client crashes, and Android desktop appears. The command “ps | grep xibo” doesn’t show the process running.
The client restarts itself after 3 minutes of inactivity, it also appears back in the processes list.
I re-created the layout from scratch several times. It’s not that it was created in an eariler version.
Some older layouts with similar functionality work fine.
What should I do to start investigating?
I’ve got SSH access to the rooted device.
It probably goes without saying, it shouldn’t do that.
As it restarts itself after 3 minutes it is most likely being killed rather than crashing - if it crashed then the process for restarting it would also have been terminated.
An educated guess as to why it is being killed - memory pressure - it is possible that it is running out of memory. If you were to take a copy of the layout without the 27 images on it, does it still exhibit the same behaviour?
I reduced the number of pictures to 4. Let me see what happens now.
However, this is an issue. A signage display should be able to display tens of pictures (maybe even a hundred) in a slideshow without any problem these days.
If that woild be the case, I’d expect a recommendation for maximum individual picture sizes in a slideshow. Not only size in bytes, but size in pixels, and also thougts on picture formats and JPEG compression.
We have an improvement already logged so that the CMS is responsible for adjusting the image before it reaches the player, thereby avoiding these sorts of issues.
It would still be good to confirm that the suspicion is correct.
