Client connection problem?
Hi everyone,
Client connection problem ?
thank you in advance.
client fault
Status
Client found response content type of 'text/html;
charset=UTF-8', but expected 'text/xml'.
The request failed with the error message:
<br />
<b>Deprecated</b>:  Automatically populating $HTTP_RAW_POST_DATA
is deprecated and will be removed in a future version. To avoid this warning
set 'always_populate_raw_post_data' to '-1' in php.ini and use the php://input
stream instead. in <b>Unknown</b> on line
<b>0</b><br />
<br />
<b>Warning</b>:
Cannot modify header information - headers already sent in
<b>Unknown</b> on line <b>0</b><br />
<?xml version="1.0"
encoding="UTF-8"?>
<SOAP-ENV:Envelope
xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:ns1="urn:xmds"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><ns1:RegisterDisplayResponse><ActivationMessage
xsi:type="xsd:string"><?xml version="1.0"?>
<display date="2016-05-17 22:55:03"
timezone="Europe/Istanbul" status="0"
code="READY" message="Display is active and ready to
start." version_instructions=""><CollectInterval
type="int">900</CollectInterval><DownloadStartWindow
type="string">0</DownloadStartWindow><DownloadEndWindow
type="string">0</DownloadEndWindow><PowerpointEnabled
type="checkbox">0</PowerpointEnabled><StatsEnabled
type="checkbox">0</StatsEnabled><SizeX
type="double">0</SizeX><SizeY
type="double">0</SizeY><OffsetX
type="double">0</OffsetX><OffsetY
type="double">0</OffsetY><ShowInTaskbar type="checkbox">1</ShowInTaskbar><ClientInfomationCtrlKey
type="checkbox">0</ClientInfomationCtrlKey><ClientInformationKeyCode
type="word">I</ClientInformationKeyCode><CursorStartPosition
type="string">Bottom
Right</CursorStartPosition><DoubleBuffering
type="checkbox">1</DoubleBuffering><EmptyLayoutDuration
type="int">10</EmptyLayoutDuration><EnableMouse type="checkbox">0</EnableMouse><EnableShellCommands
type="checkbox">0</EnableShellCommands><ExpireModifiedLayouts
type="checkbox">1</ExpireModifiedLayouts><LogLevel
type="word">error</LogLevel><LogToDiskLocation
type="string"/><MaxConcurrentDownloads type="int">2</MaxConcurrentDownloads><ShellCommandAllowList
type="string"/><UseCefWebBrowser
type="checkbox">0</UseCefWebBrowser><SendCurrentLayoutAsStatusUpdate
type="checkbox">0</SendCurrentLayoutAsStatusUpdate><ScreenShotRequestInterval
type="int">0</ScreenShotRequestInterval><MaxLogFileUploads
type="int">3</MaxLogFileUploads><DisplayName
type="string">NETBOOK2-PC</DisplayName><ScreenShotRequested
type="checkbox">0</ScreenShotRequested></display>
</ActivationMessage></ns1:RegisterDisplayResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
mmm are you certain that CMS address you entered is correct?
You can also have a look for always_populate_raw_post_data' to '-1' in php.ini
change that and restart your web server.
Peter
problem was solved
Thank you so much.
“Teşekkürler”
“İstanbul/Turkey”
