For the original poster (OP) to fill in:
Introduction
Send the “Clear Cached Data” (found under Display->Edit->Adavanced) as command.
User Story
A few of our low-power Windows-clients need the “Clear Cached Data” command to display the most recent changes. It would be easier to send this command to a Display Group insted of opening each display individually.
For the dev team to fill in:
Status
The current status and the username of the:
- Reporter
- Drafter
- Implementer
Implementation
A broad description of the changes required.
Effected Software
Which parts of Xibo are effected
DB Schema Changes
Any necessary DB Schema Changes
