How can I change settings in the Android version of the software? I need to change the port that the clients use to connect to the CMS.
Try “delete data” from Android Application Manager.
You can find the configured webserver Port for your Xibo for Android Displays in the Display Profile settings you are using.
Log into your CMS and select the Display Settings option. Next click on the down facing arrow at the end of the Profile you are using with your Android Displays and choose Edit from the menu. The option is under the Advanced tab of the Edit Profile window, named Embedded Web Server Port
