Changing layout with a bottum ticker
Hi
I have made a ticker with an RSS feed that i want to show at the bottum of one of my monitors. But this monitor has changing layouts, so every time the layout changes the ticker starts over. Is there any way to have the layout change but the ticker beeing unaffected?
Sadly I don’t think so.
Every time whole layout reloads - when the region with the longest duration ends - ticker will also reload and start from the beginning. I assume you have the same ticker on other layouts too? That’s pretty much the same, if layout changes to new one then the ticker will start from the beginning/end of the feed(depending on your setting).
