and added config.php file in client folder with below details and an additional last line for advanced changes
<?php
$config = array(
'theme_name' => 'techbreve',
'theme_title' => 'techbreve',
'app_name' => 'Xibo',
'theme_url' => 'https://yahoo.com',
'cms_source_url' => 'https://google.com',
'cms_install_url' => 'https://rediff.com',
'cms_release_notes_url' => 'http://xibo.org.uk/manual/en/release_notes.html',
'view_path' => '../views'
i used 'view_path' => '../views'
instead of 'view_path' => '../web/theme/custom/client/views' *because once i add this line i loose access to CMS Main Page*
After all Main issue after adding last line in config.php as 'view_path' => '../views' and when i edit login.twig file or about_page.twig or about_text
there are absolutely no change reflected in the login/about pages.
its like the 'view_path' => '../views' which i used in config.php to override the default template and use custom template for advanced changes has no effect.
Please help!!
<?php
$config = array(
"Instead if i add this line 'view_path' => '../web/theme/custom/test/views'
i loose access to CMS Main Page"
and when i edit login.twig file or about_page.twig or about_text there are absolutely no change reflected in the login/about pages.
Please help!!
instead of ‘view_path’ =>‘…/web/theme/custom/client/views’
'because when i add this ‘view_path’ =>‘…/web/theme/custom/client/views’ i loose access to CMS Main Page"(strange this above line is correct but still i loose access), so i changed it to ‘view_path’ => ‘…/views’
config.php as ‘view_path’ => ‘…/views’ and when i edit login.twig file or about_page.twig or about_text(which i copied and pasted in views folder from xibo-cms/views at release/18 · xibosignage/xibo-cms · GitHub) there are absolutely no change reflected in the login/about pages.
its like the ‘view_path’ => ‘…/views’ which i used in config.php to override the default template and use custom template for advanced changes has no effect.
