Doe’s Linux player support API calls to change layouts? I am using CMS 2.3.8 with docker on ubuntu 18.04 and the latest stable version of Linux player.
I am unable to change the layout on linux player while all other displays are being updated in same group.
Hi Mohammad_Azam.
Xibo for Linux does not currently support Layout change actions. Below is a link to the enhancement, which you can use to monitor its progress. I can see it’s currently set for the version R7 milestone:
