Change designer width and height
Under Resolutions I have a 1920x1080 resolution with a designer width and height of 800x450. Since I am editing on a 2K monitor I would like to change the default size to a higher resolution instead of having to click on enlarge designer everytime.
Is there anyway of doing this since under resolution you can only change the resolution of the display and not the designer?
You can zoom the designer in to 1920x1080 and then edit at native resolution.
I know I can but that would mean I would have to click “Enlarge Designer” a couple of times everytime I open the designer.
As you can see:
http://imgur.com/B4xqSaP
That is how it’s intended to work. Most people don’t have 4K displays yet!
You could manually amend the database to change the designer size but note that’s not supported and may have other consequences, so take a backup before you do it so you can roll back if there’s a problem.
I’ll leave it as is, thanks anyway. Would be nice if you could lock the enlargement level or something similair.
If you could post it as a feature request in the Features section then it will be considered for future development.
