Installation Method
Custom install
Operating System
Centos 6.10
I just upgraded Xibo to version 3.0.0 and CAS authentication doesn’t work anymore.
When I click on “CAS Login” button, I get “Error : Internal script failure”.
I ran the debug to collect data, and I can read : “/xibo/cas/login,POST,“Route excluded from CSRF: /cas/login”,INFO” from the log.csv file.
If someone can help me to see clear, I would appreciate.
Moreover, is it possible to run a more detailed debug for CAS auth’ ?
Thanks a lot.
François.
Tony.J
July 13, 2021, 8:55am
2
Hi, i have the same error (Migration 2.3.9 to 3.0.0 failed - #6 by Tony.J ) and i didn’t found a solution…
Tony.J
August 26, 2021, 1:33pm
3
Hi, Anybody can help us with CAS Authentification who doesn’t work anymore ??
I have try to install the last 3.0.2 but i the same error…
Thanks alot.
Tony.J
September 20, 2021, 8:22am
4
Hi, Anybody can help us with CAS Authentification ?
After modifying the code to enable debugging for phpCAS it gave me better error message. It didn’t like the server port being passed as a string.
Try removing the single quotes from around the port address in the settings file, restart your web server, and try logging in again.
FYI I also noticed that I needed to add users in the webui before they could login. CAS authentication does not automatically add new users.
natasha
September 24, 2021, 10:04am
6
Thank you for bringing this to our attention, an issue has been logged here:
opened 01:40PM - 22 Sep 21 UTC
bug
I just upgraded Xibo to version 3 and CAS authentication doesn’t work anymo… re.
Tony.J
September 27, 2021, 7:44am
7
Indeed it’s works :). Thanks for your answer.
Tony
system
Closed
December 27, 2021, 1:45pm
8
