thanks for the suggestion, the site works fine though, if there were a larger rewrite issue i think i would have more issues…
i can reach the following URLs:
https://my.domain.com/xibo2/
https://my.domain.com/xibo2/api
https://my.domain.com/xibo2/api/authorize
the only one that gives a 404 is
https://my.domain.com/xibo2/api/authorize/access_token
in my xibo-cms/web/.htaccess i have the standard config
RewriteEngine On
RewriteBase /xibo2
fix authorization header
RewriteCond %{HTTP:Authorization} .+
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
requests for api authorize
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_URI} ^/api/authorize/.*$
RewriteRule ^ api/authorize/index.php [QSA,L]
requests that start with api go down to api/index.php
RewriteCond %{REQUEST_URI} ^/api/.*$
RewriteRule ^ api/index.php [QSA,L]
install
RewriteCond %{REQUEST_URI} ^/install/.*$
RewriteRule ^ install/index.php [QSA,L]
maintenance
RewriteCond %{REQUEST_URI} ^/maint/.*$
RewriteRule ^ maint/index.php [QSA,L]
all others - i.e. web
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_FILENAME} !.(css|js|png|jpg)$
RewriteCond %{REQUEST_URI} !^/dist/.*$
RewriteCond %{REQUEST_URI} !^/theme/.*$
RewriteRule ^ index.php [QSA,L]
