Can not schedule after update to 2.3.2
Version 2.3.2
linux 1.8-R4-37
After the update it is not possible to add an event to the Agenda, not as admin and not as normal user. Can someone help me out? There is no error but it is not visible, but als not displayed on the screens. I already checkt the date format, but from what i read from other users it stands correct. Events from before the update are still there
Hi and welcome,
Have you tried clearing your cache? SHIFT+F5 - there might be some browser side changes depending what you updated from and clearing the cache will make sure you’ve got the latest there.
Thanks for your reply, yes i’ve tested that. But it does not help unfortunately
Can you explain what you’ve done then please - what did you upgrade from/to, what do you see when you try and schedule. Can you also send a report fault troubleshoot file?
Thanks!
