We tried to install Xibo for Android (V2_R205) on Digital Signage Player that got Android version 5.1.1.
We are using Xibo CMS that hosted at our VPS Linux Server.
However, the video can not display. And the log message at Status shown as below…
It means you device firmware either doesn’t support the codec used for that video, or it can’t play video from its internal storage.
I would try selecting the internal shared storage from the Xibo for Android Settings menu (the screenshots you show are the Android settings and aren’t the setting you need to change).
If it still doesn’t work then I would suggest getting a better device as unfortunately video playback is entirely down to the device firmware.
