I added a campaign and I want to add layouts it. There are lots of layouts so I want to use Name and tag filter in campaign -> dropdown menu -> layouts but they aren’t working.
Thanks.
Thanks.
Did you hit the Enter key after providing name/tag ?
When you enter name/tag you need to either click outside the text box or confirm by pressing ‘Enter’ key.
Let me know if that works for you.
yes, I did but not work
Are you perhaps using older CMS version? (in this case older = not 1.7.4)
There was an issue with this filter, I believe it was fixed in 1.7.4
no, I use 1.7.4 but I can’t filter
Are you both definitely trying the same filter?
