ozgunb
November 14, 2017, 2:22pm
1
I need to make a SOAP call over curl. Currently, I am trying on Postman (then generate code for curl on postman), however i failed. Is that even possible?
My curl command look like this:
curl --request POST \
--url 'http://localhost:80/xmds.php?v=4&wsdl=' \
--header 'cache-control: no-cache' \
--header 'content-type: text/xml' \
--header 'postman-token: 8df91f38-f851-d300-624c-d2b048418be4' \
--data '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xmds="urn:xmds">\n <soapenv:Header/>\n <soapenv:Body>\n <xmds:RegisterDisplay>\n <xmds:serverKey>7HM5rB</xmds:serverKey>\n <xmds:hardwareKey>12345</xmds:hardwareKey>\n </xmds:RegisterDisplay>\n </soapenv:Body>\n</soapenv:Envelope>'
Peter
November 14, 2017, 2:33pm
2
It is possible to use xmds calls via postman
for example schedule xmds call is:
POST {{url}}/xmds.php?v=5
In headers:
Content-Type text/xml
in body:
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:tns="urn:xmds" xmlns:types="urn:xmds/encodedTypes" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<tns:Schedule>
<serverKey xsi:type="xsd:string">{{serverKey}}</serverKey>
<hardwareKey xsi:type="xsd:string">{{hardwareKey}}</hardwareKey>
</tns:Schedule>
</soap:Body>
</soap:Envelope>
Obviously assuming that environment is configured and {{url}}, {{serverKey}}, {{HardwareKey}} are set in it.
All other xmds calls are constructed with the same logic, but of course require different parameters etc.
https://xibo.org.uk/manual/en/xmds.html
