Hi
I’m trying to implement a calendar that uses Google Calendar ical as a feed.
It works otherwise as expected, but in the description if I use enter to get a new line, it does not work in Xibo, everything is just one long line.
I checked the raw ical feed, and the enter press is indeed there (as an \n) but this does not cause Xibo to break the line.
Is there something I have overlooked or is this just not implemented?
I’m using Xibo cloud CMS Version 2.3.7
Regards,
Tobbe
Update:
I found a workaround. I used
white-space: pre-line;
to force it to respect the \n (I checked the source code, the \n linebreak is there)
Hopefully this will help someone
