Cache not ready
Suddenly, we encountered an issue with a large number of displays. Out of nowhere, they started showing a “cache not ready” error. It’s probably the RSS widget. All standard things work. The RSS feeds are not showing. On de player PC we kan open the link in the browser. So te player PC (windows) can acces it. With CURL on the docker cms we can also access the RSS.
To troubleshoot, we upgraded the CMS to the latest version and did the same for all the players. However, the issue persists. We’ve tried reconfiguring XMR multiple times and have also reinstalled the player several times. While reinstalling sometimes resolves the problem, it often doesn’t—and when it does work, the fix seems to be temporary.
We’ve also tried removing and re-adding the screens in the CMS, but that hasn’t helped either.
At this point, we’re stuck. Does anyone have any suggestions on what to try next?
