lrs
1
first community post, so “hi everybody”
My question is: there’s a way to bulk set an animation/transition in a playlist?
In case of dozens of items or if it’s dynamic would be great to be able to set the animation as is for the duration (as in RSS ticker).
Same apply to the images in layouts: if I upload multiple items in an image widget I have to set the transitions for everyone, manually.
There’s already in place a solution?
Thank you
natasha
2
We will be including default transition types in 2.2 which can be set from the CMS settings page to pre populate the edit transition form.
I have moved your topic to the features category to request that default transition settings could be auto applied to all widgets.
natasha
Closed
5
This topic was automatically closed after 68 days. New replies are no longer allowed.
