BUG Menuboard category renaming not effects layout
Android DSCX95
v4 R406
Renaming of a menuboard category not considered in layout editor
Steps to check behavior:
  1. create menuboard “Test”, categories “Cat1” and product “P1”
  2. Create layout and use menuboard category name and product name
  3. publish layout
  4. Change menuboard category name to “Cat2”
  5. change layout: “Cat2” will not shown in Layout-editor (still “Cat1”), but in editor bar (right side), the changed name is displayed “Cat2”
Only workaround we found:
Delete the category and reassign products again
Thank you for posting, we have identified an issue as reported here: Menuboard | Renaming a Category does not update in CMS Layout Editor · Issue #3596 · xibosignage/xibo · GitHub
