Bug: Add Column to Dataset
4.2.0
Docker
If i add a column to a dataset and set it to “Remote”, the fields doesn’t change. Maybe the problem is only at a specific language (german).
Thank you for posting.
I have passed this to our dev team for further investigation.
Thank you for bringing this to our attention. We’ve looked into the issue, and we’ve posted a bug report for the development team to investigate further. You can track the progress here: Dataset column fields do not update when set to "Remote" · Issue #3598 · xibosignage/xibo · GitHub
