Brower emulation
Hello
Xibo has an emulation of internet explorer in built, but with windows 10 does it use edge?
If so can it be avoided or changed in something else?
Nick
I have seen in other posts that Xibo is using the IE engine regardless of Windows 10 and Edge, so you should be ok, as long as IE is acceptable. Also, you can force the Xibo IE engine to emulate IE 11 by setting it in the Registry:
I had a bit of difficulty with setting that correctly, so I’ll include the screen shot that was shared with me to be sure the setting was in the correct location within the registry:
https://community.xibo.org.uk/uploads/default/optimized/2X/4/4bc9337c2d363df88178febaff5614b63e34accc_1_690x77.png
Hope that helps!
Thank you for your help.
Nick
