Blank Page on installation
Installation Method
Custom install
Operating System
Centos Nethserver
Hi All i have a problem when i want to install a fresh install of Xibo 2.3.9
I have a blank screen when i go to /web/install
It’s a web server with another site With subdirectory. I have Joomla, wordpress installed with no problem.
Is it possible this problem is the .htaccess ??
Thank’s for your help.
Hi Elbertondu62,
Have you seen the Prepare your Environment guide? : https://xibo.org.uk/docs/setup/prepare-your-environment
This should have the answers to your problem.
Kind Regards,
Frazer
Hi thanks.
Yes Its à virtual host.
I need ton create a Htaccess on the root directory liké that :
<VirtualHost *:80>
DocumentRoot “/var/www/xibo”
ServerName mydomain.com
# Other directives here
AllowOverride All
Options Indexes FollowSymLinks MultiViews
Order allow,deny
Allow from all
Require all granted
